images
I really hope this is not true:
With the flex 200 i was able to make one default template. When i copied this image to a new customer, and added the usg flex 200 i got an perfect new configured firewall with our settings etc. (vlans and everything). This seems not possible with the 50h. It would be very dissapointing if this is not possible.
FLEX H are still new the config is not the same at some point all may be added.
or are you saying you can't take the config locally of 50h to another?
no by nebula itself.
is there a cli manual? Looking now how to solve this. It's a big issue for us.
I found the cli manual. but i can't find a way to create interfaces through the CLI. is it possible to create interfaces through the CLI?
Currently, the Nebula configuration template is not supported for H series Firewall yet. I suggest that using local Web GUI to download the configuration as a configuration template, and upload to other 50H Firewalls.
You can download/upload/apply the configuration at Maintenance > File Manager > Configuration File.0
- 441 Beta Program
- 293 Service & License
