2 AP stopped working with GS1900-24EP
2»
    PeterUK Posts: 4,741
    image  Guru Member
    So you connect a new AP in the same place as the two AP's that don't work and it works?
    image  Guru Member
    That seems odd the switch looks to be working fine.
    But then I don't get why the AP's work fine without the switch maybe its something to do with Unifi Cloud Key that the AP can't talk to it?
  • SwitchAnon
    SwitchAnon Posts: 7
    image  Freshman Member
    Indeed, ut's such a wierd problem. The Cloud Key can talk to the AP just fine if I connect another Zyxel switch (GS1005HP).
    Router > Technicolor TG799vn v2 / Unifi Cloud Key 2 > Zyxel Switch GS1900 > AP = NOT WORKING
    Router > Technicolor TG799vn v2 / Unifi Cloud Key 2 > Zyxel Switch GS1005HP > AP = WORKING
    Any ideas?
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,127
    image  Zyxel Employee
    Hi @SwitchAnon,
    Thanks for sharing the topology. Could you share more details like: which switch port connects to AP and which port connects to Technicolor TG799vn v2 / Unifi Cloud Key 2 or router?
    And this issue is that the some AP can't communicate with Technicolor TG799vn v2 / Unifi Cloud Key 2? Can the AP wireless client access Internet?
    Zyxel Melen
