Converter Is Not Useful... (Not usable at all actually, updated!)
MikeForshock
MikeForshock Posts: 57  Ally Member
edited May 8 in USG FLEX H Series
Tried the converter from a FLEX 100 to a FLEX H 100 and the result is much less than good:
All my users are gone (only admins)
DHCP items were skipped
Content Filtering trust and block lists are gone
Havent tried to load it, but it may not be worth the debugging.
  • MikeForshock
    UPDATE: Config locks the router… Shows login on HTTP, but will not redirect to HTTPS (custom port) and no errors are produced.
    Login shows, enter username and password click and the page simple stops responding.
    No response from router, cannot login.
    Basically starting from scratch… Should have just got the the FLEX and skipped all the Nebula config garbage.
    Think this party is over…
  • MikeForshock
  • Zyxel_James
    Zyxel_James Posts: 788  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Could you provide your USG FLEX 100 configuration via private message, I will check on this for you, thanks.
