Nebula GEO IP Blocking
Ratsnackbar
in Security
In Nebula if you wished to use the GEO IP Blocking feature, it used to restrict you to only inputting 10 countries per rule. However I am now finding that it allows me to add more than 10 countries in a sigle GEO IP Filtering rule.
Has the 10 country limit been removed entirely? Or has it been raised to a higher number of countries per rule and if so how many? Or is this just a bug and I should not actually be able to enter more than 10 countries.
Now you can input up to 30 GEO IP (country) objects per policy.
Thanks James!
- 441 Beta Program
- 293 Service & License
