Nebula GEO IP Blocking
Ratsnackbar
Ratsnackbar Posts: 27  Freshman Member
In Nebula if you wished to use the GEO IP Blocking feature, it used to restrict you to only inputting 10 countries per rule. However I am now finding that it allows me to add more than 10 countries in a sigle GEO IP Filtering rule.
Has the 10 country limit been removed entirely? Or has it been raised to a higher number of countries per rule and if so how many? Or is this just a bug and I should not actually be able to enter more than 10 countries.
  • Zyxel_James
    Zyxel_James Posts: 788  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Now you can input up to 30 GEO IP (country) objects per policy.
  • Zyxel_James
  • Ratsnackbar
    Thanks James!
