Where is all the documentation for SecuExtender?
Many thanks for this, I have seen this after posting my previous message. Will try it out, thanks!
Yipee, the manual configuration without a documentation what means each field and where to find it on the firewall, is almost impossible.
I don't know if that is the idea, but following worked- I installed the SecuExtender for win11, and when in same LAN as the firewall USG20VPN, entered the IP and the username and password of a IPSec VPN, and it could download respectively create the proper configuration file. That was smooth!
I also need IPSec access for Macs, will go into the config soon and see how straightforward that one is- seeing the other topics around, does not seem to be a straight forward line :)
Big next question:
SecuExtender supposedly supports 2FA as well, whilst anything else does not support 2FA.
If I enable 2FA and SecuExtender will work with it, the smartphones using StrongSwan will then not work? Is there a way to configure both worlds to work simultaneously on the same firewall, ie the SecuExtender with 2FA and everything else like StrongSwan/Android without 2FA?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
