XS1930-12HP excessive port errors at 2.5GbE speed, no errors at other speeds
I have a XS1930-12HP. I've recently started to add some 2.5GbE devices. The first devices were three Unifi U7-Pro access points. Performance was terrible. After checking the port status on the switch I saw excessive port errors on the ports used by the access points. When I say excessive, I mean several thousand errors in a few minutes. I did some cable testing on my house structured cabling (Cat6) and did get some errors so I've purchased some new keystones so I can re-terminate them but haven't got round to doing this yet. I've set these ports to run at 1G/F and there are no (zero) port errors and this has been stable for a couple of months.
The U7-Pro's were the only 2.5GbE devices I've ever connected until I purchased a QNAP NAS. The QNAP web interface was incredibly slow and file transfers from a PC with 1GbE connection were only achieving around 3 to 15MB/s. The switch displayed port errors on the QNAP connection. If I change the switch port speed to 1G/F the port errors stop increasing, the QNAP web interface responds quickly and file transfers from the 1GbE PC are as expected at 110MB/s.
I also have a Synology NAS with a 10GbE network card. This has been running 24/7 for over a year at 10G/F (port set to Auto) and I've never seen a single error on the Synology's port. I tested it at 2.5GbE by setting the switch port speed and got the same results as the QNAP at 2.5G/F - slow web interface and file transfers at 2 to 15MB/s and several thousand port errors in a few minutes. If I set the port back to Auto and run at 10G/F, performance returns back to normal and the port errors stop increasing. I also tested the Synology at 5G/F and got no port errors.
I did have another Synology with a 10GbE card but I've just sold it. That never had any port errors at 10G/F.
So far I've tested ports 2, 3, 5, 7, 8, 9 and 10 and they all error at 2.5G/F and don't error at other speeds.
I've also downgraded the firmware to V4.80(ABQF.3) and get the same results. It's now running on V4.80(ABQF.4) again.
Hardware version is v1.2
There are no suspicious entries in the System Log.
Shall I create a Tech Support file?
Updaate:
After checking the tech support file > configuration part, I found that the AP connecting ports are enabling the green Ethernet function. Since this might cause the transmit voltage level mismatch between the two devices, which leads to CRC errors and poor transmit speed, disabling this function will help fix this issue.
Zyxel Melen1
Please help me collect the tech support file first. I will send you a private message for it.
Zyxel Melen0 -
Tech support file sent.
I did another test with one of the U7-Pro's directly connected to the switch, therefore not using my house structured cabling. Port errors encountered at 2.5G/F (port set to Auto) and no port errors when set to 1G/F.
I forgot to mention the Synology, QNAP and PC do not use the structured cabling.
Updaate:
Zyxel Melen1 -
Disabling the green ethernet options has eliminated the port errors and my structured cabling appears to be OK too.
Many thanks @Zyxel_Melen
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
