Zyxel VES1724-56B2
Hi Avivm,
Have you check the user guide?
Supposedly user guide will included the pin assignment mapping table.
Cheers,0 -
I haven't received user guide, where can I find it online?0
Hi Avivm,
You can check with ZYXEL local support in your region to get the user guide.
As I remember it should be standard V type telco 50 cable. telco-50 female pin assignments will like below:
Thanks! will do0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
