Security Policies geo blocking
Dpj
Dpj Posts: 213 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
edited May 2025 in USG FLEX H Series
hello,
Hmm again a feature i'm missing in de security policies. something what was just there with the flex 200. i cannot use geo blocking. (like i allow this only from germany for example).
I really hope this will be possible soon.
yours dennis
  • Dpj
    ah i see, it's working in a different way as the usg flex 200 it seems. but clear it's working
    edited May 2025
    are you doing it right?
    note default rules may allow all disable if needed
  • Dpj
    my mistake, not complete question… i mean in nebula, but i will configure it locally, and then see what happens in nebula.. at least in nebula i cannot choose any country. keep you informed
  • Dpj
