I'm not able to download the ZON utility for my GS1900-24E swtich
HI @Sonar ,
ZON is a tool designed for the effortless deployment and management of various Zyxel network devices. You can download ZON at this link:
Note: The screen you shared only shows materials specific to the GS1900-24E, not include the ZON download.
Zyxel_Judy
HI @Sonar ,
Zyxel_Judy
There is no link to the ZON Utility. When you click on "Download ZON Utility", it takes you to a page where you select your product. When you select your product, it takes you to a page like what is in the OP's screenshot: links to a bunch of files but no link to the ZON utility download.
Hi @asincero
Please scroll down and enter the contact info. We will send you the download link to your email.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
