Help with right backup configuration commands
Dion
Dion Posts: 1 image  Freshman Member
I'm struggling with the right commands to backup configurations on the switch's internal memory, view the backed up file and restore the backed up file. And also how to configure SNMPv3 on this model OLT1404B-IA
  • GoldenW
    GoldenW Posts: 10 image  Freshman Member
    First Comment First Answer
    Hi Dion,
    I have encountered similar operating problems as you before. But I found a website that provides the user manual of OLT1404 and there are detailed steps on P.308 and P309. I think this can help you.
    https://www.scribd.com/document/456709787/OLT1408A-User-s-Guide-Partner-Version-V1
