remote LAN access from VPN SSL
Good morning everyone.
I configured a VPN SSL on USG FLEX 100.
The IP range assigned to VPN users is this: 192.168.100.70-192.168.100.80. For the rest I think I left everything at default, for example in the VPN SSL settings in the NETWORK EXTENSION LOCAL IP item I left 192.168.200.1. From home I connect without problems via SecuExtender, but I can't ping (and therefore access) the remote Server and its folders, with IP 192.168.1.8.
To be able to do this I necessarily have to adjust the IP range of the VPN SSL to the same IP class as the remote network, but I would like to avoid creating possible conflicts.
Is there a way to make users who connect to vpn with ip 192.168.100.x be able to ping the remote lan 192.168.1.x?
thanks to all
Does the remote lan device at 192.168.1.8 have a gateway IP set for it?
is 192.168.100.70-192.168.100.80 not used else where?
The server 192.168.1.8 has a different gateway, but is in the same subnet as the firewall (192.168.1.x).
Do I necessarily have to set the gateway to the 192.168.1.8 device so that it points to the firewall?
I confirm that 192.168.100.70-192.168.100.80 is not used elsewhere
You mean device at 192.168.1.8 gateway is not set to FLEX 100 as the gateway but another router?
Do you set up the necessary Security Policies from WAN to ZyWall and from your SSL VPN Zone to your Destination Zone (in LAN)?
- 435 Beta Program
- 175 Nebula Ideas
- 422 USG FLEX H Series
- 297 Security Ideas
- 273 Service & License
- 418 News and Release
- 89 Security Highlight
