usg 210 kernel panic
One of our usg 210 firewall stopped working.
Message is:
We tried to reload firmware:
Message is:
Booting...
Start to check file system...
/dev/sda3: 480/20480 files (0.6% non-contiguous), 75445/81920 blocks
/dev/sda4: 198/23040 files (3.0% non-contiguous), 20926/92160 blocks
Done
mount: wrong fs type, bad option, bad superblock on /dev/loop0,
missing codepage or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
Kernel panic - not syncing: Attempted to kill init!
BootModule Version: V1.08 | 08/15/2013 10:45:46
DRAM: Size = 1024 Mbytes
Press any key to enter debug mode within 3 seconds.
Enter Debug Mode
USG210> atur
ERROR
USG210> atkz -f -i 192.168.1.1
-f
OK
atkz -f -l 192.168.1.1
USG210>
ERROR
USG210> atgof
Booting...
Connect a computer to port 1 and FTP to 192.168.1.1 to upload the new file.
Firmware received ...
Could not write 8 blocks in inode table starting at 65539: Attempt to write bloc
k from filesystem resulted in short write
/dev/sda3: 11/20480 files (0.0% non-contiguous), 6720/81920 blocks
/dev/sda4: 11/23040 files (0.0% non-contiguous), 7044/92160 blocks
Done
Building ...
[Update Filesystem]
Updating Code
done
dmesg | tail or so
[Update Kernel]
Extracting Kernel Image
done
Writing Kernel Image ... done
Validate Kernel Image ... done
Restarting system.
U-Boot 2011.03 (Development build, svnversion: u-boot:425:427M, exec:exported) (
Build time: Aug 20 2013 - 14:09:25)
mount: wrong fs type, bad option, bad superblock on /dev/sda6,
dmesg | tail or so
Any ideas?
Hi @selexi
I will send you private message for check this issue more details.
Hi @selexi
I don't know what have you done on this device and it caused device file system broken then leads device unable boots up.
So recovery system DataBase can resolve this situation.
And it's good hear the device is able work now.
- 588 USG FLEX H Series
- 477 News and Release
