remote LAN access from VPN SSL
methesrl
methesrl Posts: 3 image  Freshman Member
Good morning everyone.
I configured a VPN SSL on USG FLEX 100.
The IP range assigned to VPN users is this: 192.168.100.70-192.168.100.80. For the rest I think I left everything at default, for example in the VPN SSL settings in the NETWORK EXTENSION LOCAL IP item I left 192.168.200.1. From home I connect without problems via SecuExtender, but I can't ping (and therefore access) the remote Server and its folders, with IP 192.168.1.8.
To be able to do this I necessarily have to adjust the IP range of the VPN SSL to the same IP class as the remote network, but I would like to avoid creating possible conflicts.
Is there a way to make users who connect to vpn with ip 192.168.100.x be able to ping the remote lan 192.168.1.x?
thanks to all
    PeterUK Posts: 4,415 image  Guru Member
    edited May 2025
    Does the remote lan device at 192.168.1.8 have a gateway IP set for it?
    is 192.168.100.70-192.168.100.80 not used else where?
  • methesrl
    The server 192.168.1.8 has a different gateway, but is in the same subnet as the firewall (192.168.1.x).
    Do I necessarily have to set the gateway to the 192.168.1.8 device so that it points to the firewall?
    I confirm that 192.168.100.70-192.168.100.80 is not used elsewhere
    You mean device at 192.168.1.8 gateway is not set to FLEX 100 as the gateway but another router?
  • USG_User
    USG_User Posts: 400 image  Master Member
    Do you set up the necessary Security Policies from WAN to ZyWall and from your SSL VPN Zone to your Destination Zone (in LAN)?
