bug nat rules
Dpj
Dpj Posts: 188 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
ik think i found a small bug in nebula. I'm configuring nat rules
when i create an rule, i see External port and Internal port filled in onpremise, but when i look in nebula, those 2 are empty.
when i edit the settings of this rule, i don't see external port and internal port they are called external and internal service.
yours dennis
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,944 image  Guru Member
    Hi @Dpj,
    Could you share some screenshots with us to indentify this issue? Also, it will help us to confirm the replicate result. Thanks~
    Zyxel Melen
  • Dpj
    hmm i see it's not a bug, but can be a litte bit more clear in Nebula. I just use services, not ports
    so on premise is see this:
    in nebula is see this:
    external port is empty, offcourse when i see the details i can see the services.
    i think that can be more clear.
    yours dennis
  • Zyxel_Melen
    Hi @Dpj
    I checked in my lab and this is more likely a display bug. We will fix this and then update you.
    Zyxel Melen
