Zyxel FWA710 down during high workload on link 2.5 Gbe
sztolpenOS
sztolpenOS Posts: 1 image  Freshman Member
Hi all,
I have an issue, when Zyxel Fwa710, connected to PoE++ and 2,5Gb port (switch USW Pro Max 24 PoE) stucked when high usage is occur. Only way to retreive connecton is cycle PoE. Cable between switch-Zyxel is cat 7 S/FTP (~20meters)
After changing port link speed to 1Gbps FDX - issue dosen't occur.
Any ideas what can I do?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @sztolpenOS,
    May I clarify some information with you?
    1. FWA710's firmware version.
    2. If there is any CRC error on the switch port counter.
    3. Which traffic or service did you use and cause high usage?
    Zyxel Melen
