2FA Remote Access VPN (Flex 200H V1.32(ABWV.0) )
Hi!
My client has a Flex 200H V1.32(ABWV.0) firewall and we - the network administrators - are using/enabling IPSec VPN for the networks users to access the network remotely.
(Also using SSL VPN with OpenVPN.)
From the beginnings we used "native clients built into Windows" in win10/11 for "home office" users.
They are downloadable (from the firewall GUI) configurations for windows and macOS. It needs user name and password after the VPN is installed as the 1st authentication.
Without the 2nd authentication nor internet, nor the client's intranet worked for anyone who did the 1st authentication, except for an intranet site (firewall LAN address plus port number: 192.168.X.X:XXXX) was available for the 2nd authentication.
After the 2nd authentication both internet and full intranet became available.
But since yesterday (2025.06.02.) the 1st authentication enables both the internet and the intranet without the 2nd authentication.
How is this possible?
Hi @Danee,
After checking, the 2FA authentication for remote access VPN requires to enable security policy. May I know if you disable the security policy?
If not, could you share your configuration so we can have further checking for this issue?
Zyxel Melen0
It does look like it should not be possible
if you go to VPN status > IPSec VPN > remote access VPN can you disconnect everyone? then test again
I can/could disconnect anyone from there, and they can/could reconnect the same - non 2FA - way
with access to both inter- and intranet.0 -
Hi @Danee,
I can replicate this issue in my lab. We are investigating this issue, and I will update once I get further information.
Zyxel Melen0 -
Hi @Danee,
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 500 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
