200H with 1.32 - Only 2 CPUs working
GiuseppeR
GiuseppeR Posts: 427  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
when I go into CPU details of my 200H I see that only first 2 CPUs are working:
also under heavy load (like collecting diag infos).
Is this correct?
Core3 and 4 are not enabled to increase performances?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @GiuseppeR ,
    Based on the system architecture:
    • Core 1 & Core 2 handle firewall system operations, GUI display, and other processes (including diagnostic file collection)
    • Core 3 & Core 4 are dedicated to traffic forwarding and traffic routing functions. From the screenshot you provided, it appears that your 200H device is currently processing minimal traffic load.
    Zyxel_Judy
  • Zyxel_Judy
    Hi @GiuseppeR ,
    Zyxel_Judy
  • GiuseppeR
    Hello @Zyxel_Judy
    thanks for these details, I thought they were all usable by the system.
    I'll add massive traffic from P2P to check the other 2 Cores, I'll update you if I see no usage.
    Is traffic inspection managed only by Core 3 and Core4?
  • Zyxel_Judy
    Hi @GiuseppeR ,
    Yes.
    Zyxel_Judy
