Standalone and / or Nebula ?
jef
jef Posts: 92 image  Ally Member
I have been using the "Standalone" management believing I had to pick Standalone or Nebula and stick with that choice.
Can I use either AND both Standalone and Nebula management styles at the same time, which ever one I want, anytime I want?
Does Model matter, I have a 700 and a 700H.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @jef ,
    The USG FLEX H series devices, such as the USG FLEX 700H, require management through the Nebula Control Center (NCC) for core operations like device and license registration. Other configurations can be done via the local web GUI or the Nebula control center. P.S. Some of the functions might not be available on Nebula yet. Please follow the new and release categories for the news.
    Non-H series models, like the USG FLEX 700, can operate in Standalone mode or be registered to Nebula for Nebula mode, or Nebula monitoring mode, but typically do not support simultaneous full management from both platforms or free switching without configuration changes (often requiring a reset for Nebula onboarding).
    Zyxel Melen
  • Zyxel_Melen
    Hi @jef ,
    Zyxel Melen
    Looks like H series was done right so that you can use either Standalone or Nebula and the config will be updated either side?
