How to send messages from a XMG1915-10E to a syslogserver
Louis2
Louis2 Posts: 2 image  Freshman Member
I am probably overlooking something, but I do not manage to forward alarms from my XMG1915-10E to my GrayLog VM.
It should be so simple …
Do here my initial setup
  • I did select all possible alarms all levels for a start and testing
  • I defined a syslog server
  • And assumed that the facility number is corresponding with the index number as related to the syslog server (but that is no where documented)
  • I also tried local use 0
  • I assume that the messages will be forwarded from the switch management IP
  • And forwarding to a not existing syslog server in the management IP vlan I am using for this switch
Since I did not receive any message on my GrayLog VM (also not when switching a port on and off, or login and out), I looked at the data stream with wireshark .. all nothing.
So I am probably overlook something …. but I did not manage ….
Pleas help
PS, using the latest firmware version
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,048 image  Zyxel Employee
    Hi @Louis2,
    https://download.zyxel.com/XMG1915-10E/handbook/XMG1915-10E_2023.1.pdf
    Your configuration is the same as our handbook, so could you help to check if your switch can reach the Graylog VM? You may access Menu > Maintenance > Diagnostic to do ping test.
    P.S. VM NIC setting should be bridge or the switch might not be able to access VM.
    Zyxel Melen
  • Louis2
    Yep could be reached as expect ping times < 1 ms
    And the good news is it seems to work! Note I have only one alarm type 'authentication: HTTP(s) user admin login'
    despite selecting all possible events 0-7 however it proofs that the communication is working
