Flex 200 - Email Two Factor Auth
it works but you can't Auth on the same device because traffic down the VPN will be blocked so if you have a phone to check Email and Auth by that
Hi @mm_bret,
You will need to setup Mail server via Menu > Configuration > System > Notification > Mail server first.
Please reference to our Handbook P757. You can use gmail for SMTP mail server. Example screenshot
Then create the VPN user account with email address, and enable VPN authentication. Please reference to our Handbook P599 How to Use Two Factor with Google Authenticator for VPN
Access. (This topic has similar configuration steps for you to reference.)From my test, I can see the authentication email sent successfully.
Hope this helps.
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
