Flex 200 - Email Two Factor Auth
mm_bret
mm_bret Posts: 71 image  Ally Member
Want to get the facts about 2 Factor Auth using email.
Does it work?
If anyone has this working, or a link to the steps, would be interested.
    PeterUK Posts: 4,426 image  Guru Member
    it works but you can't Auth on the same device because traffic down the VPN will be blocked so if you have a phone to check Email and Auth by that
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,622 image  Zyxel Employee
    Hi @mm_bret,
    You will need to setup Mail server via Menu > Configuration > System > Notification > Mail server first.
    Please reference to our Handbook P757. You can use gmail for SMTP mail server. Example screenshot
    Then create the VPN user account with email address, and enable VPN authentication. Please reference to our Handbook P599 How to Use Two Factor with Google Authenticator for VPN
    Access.
    (This topic has similar configuration steps for you to reference.)
    From my test, I can see the authentication email sent successfully.
    Hope this helps.
    Zyxel Melen
