USG Flex 100 H Remote Access VPN (IPSec) problem
Last time I set one of these up it was using pre-shared key, and it all worked fine. This has me stumped, though.
I've configured the Remote Access IPSec VPN on the USG:
I/f: ppp1 (it's a PPPoE pass-through log-in on ge1)
Zone: IPSec_VPN
Split tunnel: LAN 1 subnet range
Client network: subnet that doesn't clash with LAN1 or remote subnet
Auth server: local
User: user created for testing
I have an older version of the client software, so to avoid complication (ho ho) am trying to use the Windows VPN client (Win 11). Download the setup batch file and certificate and created the VPN card.
The connection comes up and prompts for credentials. I give the relevant user/password and then it just spins until it times out.
I've looked for step-by-step guides, but can't find anything current that shows anything different to what I'm doing.
Hi @Finglow,
This issue is because the firewall generate the script lacks of routing rules for the split-tunnel. This issue will be fixed in the next firmware release.
Zyxel Melen0
Firmware 1.32(ABXF.0)
Hi @Finglow,
Zyxel Melen0 -
I have used the revised script sent privately, but am still unable to access devices on the remote LAN when the VPN is connected.
Apologies, I can't see a way to de-flag the answer.
Although the new script is allowing authentication, no traffic is routing over the VPN. Any attempt to ping or tracert to the remote LAN times out at the first hop, although the loca routing table shows the Client Network as the route to the remote LAN.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
