Uplink a L3 switch with multi vlans to 700H via SFP.
Hi @jef ,
We assume that you want to add p3 (RJ45) and p14 (SFP+) to the VLAN10 interface as members, for example. Unfortunately, this configuration cannot be implemented due to a design limitation mentioned in our Release Notes.
However, if you simply want clients connected to p3 and p14 to communicate with each other, you can configure p14 with a different VLAN. The firewall will handle inter-VLAN routing to enable communication between the ports.
Zyxel_Judy
Thanks, I figured it out the hard way, but I appreciate the confirmation.
Can p13 and p14 be grouped together? Please say yes..
P13 and P14 cannot be grouped together and must be configured as individual ports.
Zyxel_Judy
Thanks, not the answer I was hoping for but still very much appreciated.
Could this be resolved in future firmware? Because that is a problem, vlans are about grouping ports.0 -
Hi @jef ,
In the next firmware version 1.35, USG FLEX H supports LAG over VLAN.
Step 1. Create a LAG interface "lag0" and add members P13 and P14.
Step 2. Create a VLAN interface and select LAG interface "lag0" as the member.
Scheduled release time: in the end of July.
To learn about enhancements, new features, and release dates, please follow the Firewall news & release.
Zyxel_Judy
Thank you
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 500 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
