How to insert a list of URLs to block in the content filtering of an ATP200
JavierG
JavierG Posts: 3  Freshman Member
we need to insert a list of 400 URLs to block in the content filtering of an ATP200. Is it possible to do it? How would it be done?
Thank you and best regards.
  • lena78drewry
    lena78drewry Posts: 1  Freshman Member
    edited June 13
    Yes, you can block 400 URLs on a Zyxel ATP200. The most efficient method is to use the Command Line Interface (CLI) for bulk import. First, prepare a text file with one URL per line. Then, access the ATP200's CLI via SSH, Telnet, or the Web Console. Enter configure terminal, then threat-website forbid-list activate, followed by threat-website forbid. At the next prepaidcardstatus prompt, paste your entire list of URLs. Finally, exit twice and write to save the configuration. Verify the entries in the Web GUI under Reputation Filter. Ensure you have an active Content Filter license for full functionality.
