Hello amazing Community people. Advice needed please, regarding WiFi expansion.
Hello.
I currently have a SCR 50AXE, and I'm looking to expand the wifi coverage, with a additional Zyxel unit, from the below list, which will work with my 50AXE and expand the signal. I should state, that it's for my home/private system. The reason that it's there particular devices, is that I can get them for a lower price, im not looking for a new purchase. These are the choices:
SCR 50AXE
NWA50AX
NWA110AX
NWA1121-NI
NWA3560-N
NWA5123-N
Zyxel Multy M1
Zyxel Multy WSR30
WAC6502D-E
PLA5206 v2Hej.
Det vil jeg rigtig gerne, men jeg ved ikke hvem du er, eller hvad din adresse er? Men hvis du vil præsentere dig, samt din adresse, lover jeg at gøre mit aller bedste 😊
Mvh
Henrich.
Hi @Nastybaloo ,
We believe that you want to expand WiFi coverage from your SCR50AXE to enable wireless clients to roam as you move throughout your home. You can achieve this by configuring the same SSID name and security settings on your additional devices (APs, routers, etc.).
Additionally, ensure there is 15-20% overlapping coverage between the devices to maintain smooth roaming transitions.
Note: All devices you listed are possible.
Zyxel_Judy
Hi @Nastybaloo ,
Zyxel_Judy
Hi Judy.
Thanks, But am i correct in that the SCR50AXE dosnt have PoE, and i´ll need an injector for that to function?0 -
Hi @Nastybaloo ,
You're right. The SCR50AXE does not have PoE ports. To power the APs or other network devices, you can use a PoE injector or power adapters.
Zyxel_Judy
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 484 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
