200H with 1.32 - Only 2 CPUs working
GiuseppeR
Hello everyone,
when I go into CPU details of my 200H I see that only first 2 CPUs are working:
also under heavy load (like collecting diag infos).
Is this correct?
Core3 and 4 are not enabled to increase performances?
Hi @GiuseppeR ,
Based on the system architecture:
- Core 1 & Core 2 handle firewall system operations, GUI display, and other processes (including diagnostic file collection)
- Core 3 & Core 4 are dedicated to traffic forwarding and traffic routing functions. From the screenshot you provided, it appears that your 200H device is currently processing minimal traffic load.
Zyxel_Judy
Hi @GiuseppeR ,
Zyxel_Judy
Hello @Zyxel_Judy
thanks for these details, I thought they were all usable by the system.
I'll add massive traffic from P2P to check the other 2 Cores, I'll update you if I see no usage.
Is traffic inspection managed only by Core 3 and Core4?
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 484 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
