USG FLEX 500 behind other firewall - no IPV6 routing
I´m trying to set up my USG Flex 500 that is situated behind an OPNsense firewall. I went through several manuals and tutorials but I couldn´t figure out how to set it up right.
The ISP is providing Dual Stack (shared IPv4 + IPv6). The OPNsense is used to provide internet for 2 seperate company branches.
Branch 1 network is directly connected to the OPNsense LAN1 Port - IPv6 works fine.
Branch 2 uses the USG 500 behind the OPNsense LAN2 port.
So far I can use the network tool to perform an IPv6-ping to google.com on WAN1 but not on LAN1.
WAN1
ping6 2001:4860:4860::8888 -n -c 3 -I eth1PING 2001:4860:4860::8888(2001:4860:4860::8888) from 2a02:xxx6:xxx0:5401:daec:e5ff:fed5:9e0d eth1: 56 data bytes
64 bytes from 2001:4860:4860::8888: icmp_seq=1 ttl=116 time=12.6 ms
LAN1
ping6 2001:4860:4860::8888 -n -c 3 -I eth3
connect: Network is unreachable
___________________________________________
OPNsense configuration:
WAN
IPv6 Configuration Type: DHCPv6
Prefix delegation size 59
Request Prefix only - no
Send Prefix hint - yes
LAN2
IPv6 Configuration Type - Track Interface
Parent interface - WAN
Assign prefix ID - 0x1
Zyxel Configuration:
IPv6 enabled (everywhere: global, WAN1, LAN1)
WAN1
Enable Stateless Address Auto-configuration (SLAAC) - yes
DHCPv6: Client
DUID as MAC - yes
Request Address - yes
Advertised Hosts Get Network Configuration From DHCPv6 - yes
IP Address
SLAAC -- 2a02:xxx6:xxx0:5401:daec:e5ff:fed5:9e0d/64
DHCPv6 Settings LINK LOCAL -- fe80::daec:e5ff:fed5:9e0d/64
LAN1
DHCPv6 Settings
DHCPv6: Server
DHCPv6 Lease Options
DNS_Server 2001:4860:4860::8888
Enable Router Advertisement - yes
Address from DHCPv6 Prefix Delegation
IPv6_Request
::0:0:0:1/56
2a02:xxx6:xxx0:5418::1
IP Address
STATIC -- 2a02:xxx6:xxx0:5418::1/56
LINK LOCAL -- fe80::daec:e5ff:fed5:9e0f/64
Routing
IPV6 Configuration
any - none - any (Excluding Zywall) - any - any - any - any - any - WAN1 - preserve
_______________________________________________________________
So far I tried different kinds of IPV6 Requests, different prefix lengths, enabling/disabling SLAAC, different routing settings… At the moment I can't see the wood for the trees.
My questions at this point:
Is the prefix from the ISP suitable for this kind of routing at all?
Does the OPNsense provide me the right type of IPV6 network/prefix/…?
How should my request look like to enable ?
Can someone please help me and push me into the right direction? Thanks!
Hi @5x5,
To test IPv6 on LAN, please use a client to test. The network tool can't ping Internet when you select LAN interface.
Additionally, your LAN v6 configuration seems no problem.
Zyxel Melen0 -
ok, thanks for reply.
I did test the IPv6 connectivity on 2 different clients as well (ping, IPV6 test websites) but I couldn`t get a connection there either :-(
My windows PC does get these 2 IP adresses:
2a02:xxx6:xxx0:5401:f7bf:324b:5f55:80e1
2a02:xxx6:xxx0:5418:28d6:8145:5116:db29and a fe80 link local address + fe80 standard gateway
name resolution (e.g. ipv6.google.com) from any client works!
Hi 5x5
Sorry for the delayed reply since I was having some clarification.
Please note that for USG FLEX WAN and LAN, there are difference interface/subnet. For your OPNSense, it doesn't know how to reach 2a02:xxx6:xxx0:5418::1/64. So, please add static route on OPNSense and the next hop is USG FLEX WAN IP. Also, we suggest you to set static IP for your USG FLEX WAN interface. You may reference this document for more details.
Hope it helps.
Zyxel Melen0
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 463 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 439 News and Release
- 4.3K FAQ
- 91 Security Highlight
