loss of packets within a VPN ipsec tunnel
noc_aba
noc_aba Posts: 37  Freshman Member
Hello
I've a couple of ATP500 (5.40 firmware) perfectly connected to Internet. A site to site IPSEC VPN established between the two ATP500, that has worked fine for months. Today there is a significat loss of packet when a host from site A pings an host on site B, and viceversa. The Internet traffic is not affected at all. We have tried everything, the problem remains.
If we establish a VPN to each of them, from other ATP firewalsl, there is no packet loss.
Any hint ?
regards
Paolo
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,268  Zyxel Employee
    Hi @noc_aba ,
    To better understand the issue, could you share the ping results when pinging from a host on site A to a host on site B, and vice versa?
    Zyxel_Judy
  • noc_aba
    Hi Judy
    192.168.12.1 lan interface atp500 B, 192.168.1.100 lan interface of atp500 A
    VPN site-to-site is between 192.168.1.0/24 and 192.168.12.0/24.
    Problem appeared suddenly yesterday morning after months of normal working.
    pls find below a ping isuued this morning on atp500 A
    Router# ping 192.168.12.1 source 192.168.1.100 forever
    PING 192.168.12.1 (192.168.12.1) from 192.168.1.100 : 56(84) bytes of data.
    64 bytes from 192.168.12.1: icmp_seq=1 ttl=63 time=28.1 ms
    64 bytes from 192.168.12.1: icmp_seq=2 ttl=63 time=27.6 ms
    64 bytes from 192.168.12.1: icmp_seq=3 ttl=63 time=28.2 ms
    64 bytes from 192.168.12.1: icmp_seq=5 ttl=63 time=28.1 ms
    64 bytes from 192.168.12.1: icmp_seq=6 ttl=63 time=27.8 ms
    64 bytes from 192.168.12.1: icmp_seq=8 ttl=63 time=94.7 ms
    64 bytes from 192.168.12.1: icmp_seq=9 ttl=63 time=28.4 ms
    64 bytes from 192.168.12.1: icmp_seq=12 ttl=63 time=27.8 ms
    64 bytes from 192.168.12.1: icmp_seq=15 ttl=63 time=27.8 ms
    64 bytes from 192.168.12.1: icmp_seq=16 ttl=63 time=28.2 ms
    64 bytes from 192.168.12.1: icmp_seq=17 ttl=63 time=28.0 ms
    64 bytes from 192.168.12.1: icmp_seq=18 ttl=63 time=28.3 ms
    ^C
    --- 192.168.12.1 ping statistics ---
    18 packets transmitted, 12 received, 33% packet loss, time 17016ms
    rtt min/avg/max/mdev = 27.616/33.628/94.755/18.432 ms
    Router#
  • noc_aba
    and viceversa
    Password:
    Router# ping 192.168.1.100 source 192.168.12.1 forever
    PING 192.168.1.100 (192.168.1.100) from 192.168.12.1 : 56(84) bytes of data.
    64 bytes from 192.168.1.100: icmp_seq=1 ttl=63 time=28.4 ms
    64 bytes from 192.168.1.100: icmp_seq=5 ttl=63 time=28.2 ms
    64 bytes from 192.168.1.100: icmp_seq=6 ttl=63 time=28.4 ms
    64 bytes from 192.168.1.100: icmp_seq=7 ttl=63 time=28.2 ms
    64 bytes from 192.168.1.100: icmp_seq=8 ttl=63 time=27.8 ms
    64 bytes from 192.168.1.100: icmp_seq=9 ttl=63 time=28.5 ms
    64 bytes from 192.168.1.100: icmp_seq=10 ttl=63 time=28.2 ms
    64 bytes from 192.168.1.100: icmp_seq=11 ttl=63 time=34.1 ms
    64 bytes from 192.168.1.100: icmp_seq=12 ttl=63 time=27.7 ms
    64 bytes from 192.168.1.100: icmp_seq=13 ttl=63 time=27.8 ms
    64 bytes from 192.168.1.100: icmp_seq=15 ttl=63 time=30.1 ms
    64 bytes from 192.168.1.100: icmp_seq=17 ttl=63 time=28.4 ms
    ^C
    --- 192.168.1.100 ping statistics ---
    19 packets transmitted, 12 received, 36% packet loss, time 18050ms
    rtt min/avg/max/mdev = 27.784/28.870/34.185/1.703 ms
    Router#
  • noc_aba
    I forgot to say ATP500 is behind NAT. And I read on the release notes 5.40 (page 10):
    "Not support site to site VPN behind NAT scenario both in On-Premises mode and On-Cloud mode".
    However, for three days with 5.40, there were no problem in the VPN tunnel.
    PeterUK Posts: 3,820  Guru Member
    Do both ends not have subnets the other end have?
  • noc_aba
    hello
    I sai above:
    VPN site-to-site is between 192.168.1.0/24 (site A) and 192.168.12.0/24 (site B)
    edited June 13
    So like site B does not have 192.168.1.0/24 on any of its interfaces?
    if Anomaly Detection and Prevention (ADP) is enabled try disabling
  • noc_aba
    disablig ADP does not solve the problem
    edited June 13
    can you do the following by SSH on both ATP and post what they show
    show interface all
    the following will show any interface disabled
    show interface vlan
    show interface ethernet
