ZyWall110 to ATP200 conversion
I have to replace the Firewall at a customer. He is using a Zywall110 with many different settings.
The conversion tool can not convert from Zywall110 to ATP200.
So do I have to copy the settings one after another by hand or is there an other option to convert the whole configuration at once?
Hope anybody can help me.
This would save me a lot of time.
Thank you for any help :)
Hi @Chris_b4s,
The migration of Zywall110 is USG FLEX 500, therefore, you can't convert to ATP200 directly. It is because the physical interfaces are different.
Zyxel Melen0 -
thanks for the fast reply.
i saw a forum post where a member converted the config-file to an ATP200.
so it should be possible… somehow…
Hi @chrisgrass,
We are unsure what action was him do, but since physical limitation, you will need to have additional steps to configure ATP200. Like convert to USG FLEX 500 and copy the part of configuration to ATP200.
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
