XMG1915-18EP 10gb copper SFP+ shop
clarkyjp
clarkyjp Posts: 9  Freshman Member
I am really struggling to find a supplier of 10Gb SFP+ modules for the XMG1915-18EP switch. I have tried Mikrotik and 10G GTek 80m modules but I get weird ddmi errors stating things like infinite low rx and tx reading intermittently causing the link to flap up and down constantly. These modules even when relatively stable at 10Gb (seems to be with no real traffic flowing) don’t even show in the web interface or the cli as connected, even when the LED on the switch is lit blue.
can anyone point me to a retailer that can supply Zyxel 10Gb copper modules that are fully compatible?
cheers
  • clarkyjp
    I also completely forgot I also tried FS modules with the same result! Any pointers to fully compatible copper modules greatly appreciated!
  • Zyxel_Lynn
    Zyxel_Lynn Posts: 21  Zyxel Employee
    Hi, @clarkyjp
    XMG1915-18EP’s compatible SFP10G module can be found in the datasheet of XMG1915-18EP. If you want to find the datasheet of XMG1915-18EP, just follow the following directory.
    First, go to Zyxel’s official website, hover your mouse toward the Business section on the top bar, and then click on the Product section.
    Later, you will be directed to a Product Overview page. Click on the search icon (magnifying glass), and type in XMG1915 the search box.
    Next, Select the model (XMG1915-18EP) you are looking for, and you will be directed to the download library of the model (XMG1915-18EP).
    Scroll down, and you will see the table that provides datasheet, handbook, and user’s guide of the model. You can download the datasheet of XMG1915-18EP here.
    Based on the datasheet of XMG1915-18EP, the transceiver : SFP10G-T, SFP10G-SR, SFP10G-SR-E, SFP10G-LR, and SFP10G-LR-E are the recommended transceivers that are compatible with XMG1915-18EP. These five accessories can be purchased from Zyxel’s official ecommerce partners.
    In terms of Zyxel’s e-commerce partner, you can follow the following directory that helps you find the platform to purchase those accessories online.
    First, go to Zyxel’s official website, hover your mouse toward Where to buy section on the top bar, and then click on the eCommerce Partners.
    You will be directed to the eCommerce Partner for you to purchase our products and accessories online.
    Kindly be aware that the five recommended transceivers may have different availability across various e-commerce platforms. For example, Amazon carries the SFP10G-T and SFP10G-SR-E models, whereas B&H offers the SFP+10G-SR. We suggest you review each platform to determine which one best suits your particular needs.
    Through the e-commerce platform, you can conveniently purchase both Zyxel accessories and products without needing to search for additional local resellers. If you have any other questions about retail options, please feel free to ask.
    Best Regard,
    Lynn
  • clarkyjp
    I can confirm the switch is super picky around SFP+ module compatibility and only works with the Zyxel SFP+ modules I have now purchased.
    I also noted the the web interface only shows the link being connected at 10Gb even when the other side is connected to a 2.5Gb port.
    so just buy the Zyxel SFP+ copper module to save yourself some pain as I have tested quite a few non-Zyxel SFP+ copper modules which all act weirdly in the same way!
  • Zyxel_Lynn
    Thank you for your contribution and for sharing your insights.
    Should you encounter any additional issues or have further concerns, please feel free to update the forum accordingly.
    We appreciate your participation.
    Best regards,
    Lynn
