700H Problem IPS "Security Service" and IPSEC
jef
jef Posts: 90 image  Ally Member
edited June 22 in USG FLEX H Series
IPsec-VPN tunnels, the tunnel traffic gets clobber by the IPS Security Service "Prevention" feature.
If I un "Enable" IPS, the vpn tunnels function fine.
Specifically running SSH connections over the VPN to or from remote servers.
If I "Enable" IPS the tunnels drop SSH traffic, then SSH starts throwing errors:
"kex_exchange_identification: read: Connection reset by peer".
So. How do I white list all IPSec tunnel traffic from the IPS.
I would like to leave "Prevention" on. But can not with IPS wrecking SSH.
    PeterUK Posts: 4,228 image  Guru Member
    edited June 22
    If you can find the Signature you can disable it but I'm not sure which one (don't have a License to test) under Query Signatures put in IKE you will find:
    Cisco Adaptive Security Appliance IKEv1 and IKEv2 Heap Buffer-Overflow
    try disabling that also check in logs might say which one
    or in IP Exception and put in the source by IP or FQDN
  • jef
    "IP Exception and put in the source by IP or FQDN" that sounds hopeful.
    I don't know how the IPS works or the packet flow through the firewall.
    In my mind VPN is all LAN traffic and shouldn't be touched by the firewall, but again I do not understand the flow.
    And I do not understand the "signatures" and "rate bases signatures".
    This is my "IKE" query.
    My tunnels seem solid. They don't go down and don't seem to be re-establishing.
    What I do get, IPS shutdown down SSH traffic. If I am connected via ssh, is stays alive.
    But when you try to connected again, it may or may not depending on if IPS "rejects" the packets.
    "W Box: directory" is a successful ssh, to the W box, doing a "stat" on known directory.
    When it returns "directory" the ssh worked.
    But when IPS hits "kex_exchange…." And when the firewall kicks in, all LAN traffic fails.
    I'm going to try your "IP exception" idea.
  • jef
    Hey.. I believe your "IP exception" idea is working. I'll have to keep an eye on it, but my test script isn't kicking errors and turned "Prevention" back on.
    I wasn't sure how to do the IP Exceptions. I put in one for each 'gate' and one for each 'vlan' both as source.
