ZyWALL110 Error Number: -16015 Error Message: 'Dial a dynamic tunnel has failed for Crypto map.'
Vyacheslav
Vyacheslav Posts: 17  Freshman Member
edited April 2021 in Security
server does not start vpn writes such an error Error Number: -16015 Error Message: 'Dial a dynamic tunnel has failed for Crypto map.' .did all the settings as written in the manual. Please Help me.
Best Answers
  • [Deleted User]
    [Deleted User] Posts: 118  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    Dear @Vyacheslav
    Thats because you are clicking on connect in the zywal webgui (that's mainly for device to the device connection)
    L2TP in the zywall is commenly used as Server role. That means Zywall is server and u have to use a client (Windows pc, Iphone, Android) to dial in on the zywall..
    So the Zywall will not iniate the connection like you tried with hitting connect.
    here is an video how to configure a windows client:to succesfully use L2TP VPN with the zywall
    https://youtu.be/BYxcjcOxybs
«1
  • [Deleted User]
    Dear @Vyacheslav
  • Vyacheslav
    Thanks !!!
  • Vyacheslav
    edited May 2019
    info
    IKE
    ISAKMP SA [L2TP_VPN_GW] is disconnected
    info
    IKE
    Received delete notification
    info
    IKE
    Recv:[HASH][DEL]
    info
    IKE
    Send:[HASH][NOTIFY:NO_PROPOSAL_CHOSEN]
    info
    IKE
    [SA] : No proposal chosen
    info
    IKE
    [ID] : Tunnel [L2TP_VPN] Phase 2 Local policy mismatch
    info
    IKE
    Recv:[HASH][SA][NONCE][ID][ID]
    info
    IKE
    Рhase 1 IKE SA process done
    Phase 1 and Phase 2 Proposal settings are the same.
  • [Deleted User]
    Please share your tunnel setting otherwise its difficult to see what wrong
  • Vyacheslav
  • jonatan
    jonatan Posts: 190  Master Member
    Add encryption in phase 1 and phase 2
  • Vyacheslav
    edited May 2019
    In Zywall 110  (firmware 4.33) 3DES is missing. May be downgrade firmware to 4.25?
