I'm Insane: Bought another USG FLEX H expecting better
Seems I am a glutton for punishment…
Upload a config file that has an error (adding address objects vs. the Web UI) the device will factory reset and you have to start the setup all over, the firmware re-downloads (already on the latest) and start over. No option to revert like previous.
Additionally there is no log to help debug.
Using the "Test" in the config manager will always pass.
Appears that the issue now is the https cert is not the factory and isnt part of the config.
Will require a factory reset to gain access again
May I help to check this issue? I will send you a private message to get this issue configuration.
Zyxel Melen0 -
The issue is that the certificate referenced was not in the router and is not part of the config. there is a new backup option that apparently is more of a device image that may include the certificate. Granted, it doesn't appear to be a good way to clone devices.
- 435 Beta Program
- 176 Nebula Ideas
- 424 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
