ZyWALL SecuExtender end of life. How connect to VPN?
Hi users,
If you recently purchased a license, you may still be able to access the software. You can download the Windows SecuExtender SSL VPN client 4.0.5.0.
If not, you can try these 2 options:
- Use IPSec VPN instead of SSL VPN, or
- Upgrade to USG FLEX H firewall to continue using SSL VPN
Detailed information can be found at this link.
Zyxel_Judy
Does the
WindowsSecuExtender SSL VPN client 4.0.5.0] not work any more?0 -
Hi users,
Zyxel_Judy
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
