V1.32 not stable to the UI
2»
    PeterUK Posts: 3,892  Guru Member
    edited April 20
    So its been two days with the UI being stable so now I will change trunk from VLAN443 to WAN3_2_VLAN that has VLAN31, VLAN443, ge3, and ge2…
    Edit so their was no problem happening after change so now will reboot will the trunk set and the problem should happen again…
    Edit2 And back to unstable UI again
    The connection has timed out.
    Error Code: [ID: 20001]
    get-device-config
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @PeterUK ,
    Thank you for your cooperation and remote sessions.
    As confirmed in our private communication, the unstable GUI issue with your USG FLEX 200H has been fully resolved with our solution (WK25 version update).
    Zyxel_Judy
