Boot Loop & Firmware Download
GetLoDo
GetLoDo Posts: 6  Freshman Member
I factory reset a 100h and now it's stuck in a boot loop. Where can I download the firmware so I can load it on a USB? Are there particular instructions for the Flex 100h to boot from USB?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,529  Zyxel Employee
    Hi @GetLoDo,
    USG FLEX H doesn't support USB bootup.
    Could you help to connect the console and record the booting log so we can help to check what happens and provide you the next step?
    Zyxel Melen
  • GetLoDo
    Here is the SSH terminal information:
    Starting binary extension
    mv_ddr: Marvell-10.3.7.0-1 (release) (Nov 06 2023 - 01:18:57)
    using ddr topology of ZYXEL_BOARD_USGFLEX100H
    mv_ddr: completed successfully
    Booting Trusted Firmware
    BL1: Booting BL2
    BL1: Booting BL31
    U-Boot 2018.03-7.1.0 (Nov 06 2023 - 01:18:30 +0000)
    BootModule Version: V1.1.3 Nov 06 2023 01:18:30
    DRAM: Size = 4096 Mbytes
    Press any key to enter debug mode within 3 seconds.
    RAM test ........ done !
    Loading kernel from FIT Image at 20000000 ...
    Using 'conf@1' configuration
    Verifying Hash Integrity ... sha1,rsa2048:dev+ OK
    Trying 'kernel@0' kernel subimage
    Description: Linux Kernel
    Created: 2025-01-09 4:35:14 UTC
    Type: Kernel Image
    Compression: uncompressed
    Data Start: 0x200000d8
    Data Size: 24445440 Bytes = 23.3 MiB
    Architecture: AArch64
    OS: Linux
    Load Address: 0x08080000
    Entry Point: 0x08080000
    Hash algo: sha1
    Hash value: 448020f0583c5d578d2f805402cc889172a28ea2
    Verifying Hash Integrity ... sha1+ OK
    Loading fdt from FIT Image at 20000000 ...
    Trying 'fdt@0' fdt subimage
    Description: Flattened Device Tree blob
    Type: Flat Device Tree
    Data Start: 0x217503d0
    Data Size: 29126 Bytes = 28.4 KiB
    Hash algo: sha1
    Hash value: b09363b438e145cf092cad80bd0c6050fb3088f4
    Loading Kernel Image ... OK
    Start to check file system...
    /dev/mmcblk0p6: 12/65536 files (8.3% non-contiguous), 20237/262144 blocks
    /dev/mmcblk0p7: 708/118080 files (0.4% non-contiguous), 27051/472064 blocks
    Done
    mount: wrong fs type, bad option, bad superblock on /dev/loop0,
    missing codepage or other error
    In some cases useful info is found in syslog - try
    dmesg | tail or so
    mount: mount point /etc/zyxel/ftp/wtp_image does not exist
    Error: We can't mount /share/AP-image/FW1/wtp_image to /etc/zyxel/ftp/wtp_image partition
    Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000000
    CPU: 1 PID: 1 Comm: init Tainted: P O 4.14.207-10.3.7.0-2 #5
    Hardware name: Marvell Armada 7040 USG40V3 - USG4060V3_version (DT)
    Call trace:
    dump_backtrace+0x0/0x130
    show_stack+0x14/0x20
    dump_stack+0x9c/0xd8
    panic+0x118/0x290
    do_exit+0x700/0x990
    do_group_exit+0x38/0xa0
    __wake_up_parent+0x0/0x30
    __sys_trace_return+0x0/0x4
    SMP: stopping secondary CPUs
    Kernel Offset: disabled
    CPU features: 0x8,01002000
    Memory Limit: none
    Unable to handle kernel paging request at virtual address ffff0000096d4400
    Mem abort info:
    Exception class = DABT (current EL), IL = 32 bits
    SET = 0, FnV = 0
    EA = 0, S1PTW = 0
    Data abort info:
    ISV = 0, ISS = 0x00000007
    CM = 0, WnR = 0
    swapper pgtable: 4k pages, 48-bit VAs, pgd = ffff000009832000
    [ffff0000096d4400] *pgd=000000013fffe003, *pud=000000013fffd003, *pmd=000000013f ff8003, *pte=0000000000000000
    Internal error: Oops: 96000007 [#1] PREEMPT SMP
    Modules linked in: zyxel_disklog(O) watchdog_touch(O) xt_zld_ctstatus_confirmed( PO) xt_zyusergroup(O) xt_traffic_flow(O) zyxel_route_multipath(PO) libiface_modu le(O) zld_conntrack_data(O) lm96000(O) zld_mrd(PO) mv88e6191x(O) zyklog(PO) swit chdev_netlink(O) switchdev_char(O) switchdev(PO) platform_support(O)
    Process init (pid: 1, stack limit = 0xffff80013b254000)
    task: ffff80013b258000 task.stack: ffff80013b254000
    pc : _raw_spin_lock+0x14/0x50
    lr : mod_timer+0xf0/0x2f0
    sp : ffff80013b257920 pstate : a00001c5
    x29: ffff80013b257920 x28: 0000000000000022
    x27: ffff80013a5a0000 x26: 0000000000000000
    x25: 0000000000000000 x24: 00000000ffffffff
    x23: 0000000000000000 x22: 00000000fffef798
    x21: ffff0000096d4400 x20: ffff0000096d4400
    x19: ffff80013ac9f988 x18: 00000000fffffff0
    x17: 0000000000000000 x16: ffff80013b258000
    x15: ffff000009714530 x14: 74612065646f6e20
    x13: 6120676e696b6146 x12: 203a414d554e0a64
    x11: 6e756f66206e6f69 x10: 746172756769666e
    x9 : ffff80013b257c10 x8 : ffff80013b257ab0
    x7 : ffff80013b257c00 x6 : 0000000000000001
    x5 : 0000000000000001 x4 : 0000000000000040
    x3 : 0000000000000040 x2 : ffff80013b258000
    x1 : 0000000000000003 x0 : ffff0000096d4400
    Call trace:
    sdhci_send_command+0x11c/0xa30
    zymmc_simple_transfer+0x168/0x1c0 [zyxel_disklog]
    zymmc_basic_run+0xfc/0x120 [zyxel_disklog]
    diskWriteSectorUnstable.part.0+0x4c/0x60 [zyxel_disklog]
    writeLogToDisk+0x118/0x1b0 [zyxel_disklog]
    do_dump+0x64/0x80 [zyxel_disklog]
    kmsg_dump+0xc0/0x100
    panic+0x150/0x290
    do_exit+0x700/0x990
    Code: b9401041 11000421 b9001041 f9800011 (885ffc01)
    ---[ end trace c6f5e1b6f550e10a ]---
    PeterUK Posts: 3,891  Guru Member
    edited June 25
    If you press any key to enter debug mode you should be able to boot the other firmware slot?
  • GetLoDo
    I'm getting ERROR with any command I try.
    Enter Debug Mode
    USG FLEX 100H> atcb 2
    ERROR
    USG FLEX 100H>
    try
    cmd firmware boot-number 2
  • GetLoDo
    No dice.
    USG FLEX 100H> cmd firmware boot-number 2
    ERROR
    USG FLEX 100H>
    edited June 26
    You my have to wait to be given the firmware file to do this.
    How do I perform firmware recovery on USG Flex H series models? — Zyxel Community
    edit
    try
    atcd 1
    atgo
  • GetLoDo
    Thanks for your help, it might be an RMA situtation.
    @Zyxel_Melen, do you know when we can download the firmware for a Flex 100h or can you provide it to me?
  • Zyxel_Melen
    Hi @GetLoDo,
    I will send you the link and guide in the private message. Please check my message.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GetLoDo,
    I have sent you the firmware file in the private message. Please help to follow the steps to recovery the firmware. If you can't process firmware recovery, this could be an hardware issue, also because you tried change boot image but failed. Please submit a RMA request via the link I provided in the private message.
    Zyxel Melen
