Issue with connecting to the guest network through one of the repeaters
Igor7777
Igor7777 Posts: 1 image  Freshman Member
I have a Wi-Fi network. The main router is a Speedster, and there are two repeaters connected to it, both Challenger. The repeaters connect automatically through capture in the main router’s admin panel. My question is: why does one of the satellites allow connection only to the home Wi-Fi network but does not allow connecting to the guest network? On the main router and the first satellite, both networks connect without any problems.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    1. What's your model?
    2. What's your topology? Did you set mesh but not roaming?
    3. What's your config?
    Zyxel Melen
