XGS2210-52 VLAN to internet
Lorenzo_CRC_Sistemi
Lorenzo_CRC_Sistemi Posts: 4 image  Freshman Member
First Comment Seventh Anniversary
edited August 2022 in Switch
Hi everyone;
i have an issue with intra vlan routing; this is my scenario:
USG110 (P1-2:wan, P4:vlan1 192.168.1.251)
XGS2210-52 (vlan1  interface ip 192.168.1.250; vlan2 int. ip 192.168.2.250; vlan3 int. ip 192.168.3.250... etc...)
default GW 192.168.1.251.
Each client on vlans 2/3/etc... is configured with respective vlan interface ip as gateway.
Intra vlan traffic is ok, but i can't ping the external GW 192.168.1.251.
If USG is used as gateway by clients (adding Vlans ip 192.168.2/3.251 on P4 port and configuring related policies) everything works fine.
But i don't want to use USG as vlan router... (it's a bottleneck when i move TB among vlans).
Additional configuration are required on XGS / USG ?
Thanks in advance
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    edited May 2019
    Hi @Lorenzo_CRC_Sistemi
    Welcome to Zyxel community!
    Your configuration on XGS2210 is just fine.
    The problem is there are no static route rules on your USG to "route" traffic back to clients.
    Please go to web interface of USG: Network -> Routing -> Static Route
    Assign the gateway IP 192.168.1.250 for destination IP 192.168.2.0/24 and 192.168.3.0/24, etc.
    Please be aware that there might be some default interface 192.168.2.1, .3.1, .4.1 on USG.
    You must change them to other IP to avoid confusion on static route.
    In this way the backward traffic will be forwarded from 192.1.168.1.251 to 192.168.1.250, and then the XGS2210 handles "internal routing" to a specific VLAN interface, and to clients.
    Hopefully it helps.
    Zyxel_Lucious
  • Lorenzo_CRC_Sistemi
    Great Lucious
    solved!
