NWA110BE -option to configure daily report missing
I configured a new NWA110BE, did the syslog first, then went to configure the daily report but the option was no longer there.
A quick summary of steps:
switched on the NWA110BE for standalone use
configured the wifi
updated the firmware to v7.10(2)
configured the syslog to send messages to a NAS (intending to set up the daily report later)
rebooted
Went to Configuration | Log & report to set up the daily report, but the daily report config item is no longer there.
I could reset the 110BE, but I am hoping for a nicer way - what would you recommend, please?
Ta.
Hi @Robertod,
Regarding the missing option to configure the daily email report, could you please provide us with screenshots of your device's dashboard and the Log & Report interface? You can send them via private message.
Please ensure the screenshots include the full navigation panel on the left, as shown in the example picture below.
Here is another approach you can refer to configure the e-mail send from the AP.
SSH to AP and use the CLI below
Router> enableRouter# configure terminalRouter(config)# daily-reportRouter(config-daily-report)# activateRouter(config-daily-report)# smtp-address{ip | hostname}Router(config-daily-report)# smtp-port<1 .. 65535>Router(config-daily-report)# mail-frome_mailRouter(config-daily-report)# mail-to-1e_mailRouter(config-daily-report)# exitRouter(config)# exitAfter that, you can use CLI to check the daily report status:
Router# show daily-report statusOther CLI related to the Email Daily Report, you can refer to the following PDF file.
Zyxel Tina
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
