Firmwareupdate Zyxel GS1900-24E B1 from 2.8 to 2.9
Franz_Stegmaier
Franz_Stegmaier Posts: 1 image  Freshman Member
I tried to update the firmware of my Zyxel GS1900-24E B1 from version 2.8 to 2.9.
I used, Chrome, Edge, Firefox and ZON. However it always fails to update.
  • Zyxel_Tina
    Zyxel_Tina Posts: 701 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Franz_Stegmaier,
    Welcome to Zyxel Community!
    Regarding the firmware upgrade issue with your GS1900-24E switch, here are several troubleshooting steps to resolve this problem:
    1. Firmware File Format Verification
    Please ensure you are using the correct file format for the upgrade:
    • After downloading the firmware file, unzip the archive completely
    • Use the .bix extension file (not the .zip file) for the actual upgrade
    • The correct firmware version for GS1900-24E is: V2.90(AAHK.1)C0
    2. Firewall Configuration Check
    Firmware upgrade failures are commonly caused by firewall restrictions:
    • Temporarily disable your operating system firewall during the upgrade process
    • Ensure TFTP/HTTP/HTTPS services are not blocked by your security software
    • Check that your antivirus software isn't interfering with the upload process
    3. Firmware Upgrade Method
    Web UI Upgrade
    1. Access your GS1900-24E via Web UI → MaintenanceFirmware
    2. Choose the "Upload" tab and use the "HTTP" method
    3. In Image section, choose: "Backup" (for safer upgrade)
    4. Click "Browse" and select the .bix firmware file
    5. Upload the file and wait for completion
    6. After upload completion, click on the “Management” tab
    7. Select the backup image you just uploaded, and then click “Apply” to set the backup image as the boot image
    8. Navigate to MaintenanceReboot to manually restart the device
    9. After reboot, verify the firmware upgrade is completed
    If you continue experiencing issues after following these steps, please let us know the specific error messages you're encountering, and we'll provide further assistance.
    Zyxel Tina
  • Zyxel_Tina
    Web UI Upgrade
    Zyxel Tina
