Full VPN tunnel from FlexH 1.32 FW to Nebula Org firewall
13»
  • GiuseppeR
    GiuseppeR Posts: 614 image  Master Member
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
    Yes VTI are in the same subnet now, but the hidden mistake was to use the same IP (not the same subnet…) for both. I did not see this mistake because it was set once on Nebula and never checked again until some hours of testing.
    Now I have this rule working properly:
    but the local LAN of FlexH goes remotely on the first subnet it finds.
    When I set the VPN as "Custom" on FlexH I told the VPN to go to a specific remote subnet but it seems it ignores that:
    that blu "Destionation" subnet is where I wanted to have that traffic from VPN.
    Remotely I have different subnets:
    • 192.168.1.1
    • 192.168.10.1
    • 192.168.201.1 and so on….
    So the traffic from VPN has to go on a specific one.
    In reality the VPN goes to 192.168.1.1 network
    Should I used this advance area to specificy which is the remote destination?
    PeterUK Posts: 4,376 image  Guru Member
    The static route setup is not for ORG1 (FLEX H) remove it the static route setup is or ORG2
    leave NAT rule blank
    Untitled Image
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,467 image  Zyxel Employee
    Hi @GiuseppeR
    May I know the site-to-site VPN setting on org B(USG FLEX)?
    Please check if you enable "use VPN" for the second interface/subnet. If not, please enable it first.
    Then, back to USG FLEX H local GUI and navigate to Menu > Network > Routing > Static Route to check if both LAN interface/subnet has the static route rule. In my lab, I have two static route for the two LAN interface
    Once it has, you can access it from H side.
    Zyxel Melen
