How do I stop NWA50AX MBSSID defaulting SSID to slot 8 on list for Radio 2?
I'm using the Zyxel NWA50AX in standalone mode, and I've noticed that the MBSSID Settings interface always places my active SSID profile at the bottom of the list (e.g., slot 8), regardless of configuration order. This seems to only happen on Radio 2. Is there a way to fix it? Each time I set it to #1, and apply the changes, it goes right back to #8.
Thank you.
Welcome to Zyxel Community!
Normally, all slots in the MBSSID settings should be editable. We've tested this behavior using a similar model running the latest firmware version, V7.10(1), and confirmed that all slots (1–8) can freely accept any SSID profiles. You can see the demonstration in the following recording:
To help us better assist you, could you please share a video of your configuration steps as well? Also, kindly provide us your device’s diagnostic file via private message. You can refer to this FAQ for instructions on how to collect the diagnostic info file.
Zyxel Tina
- 602 USG FLEX H Series
- 480 News and Release
