Zyxel XMG1915-10E LEDs?
Does this Switch have the option to turn these off? if not, are there any LED's inside the ports or only on the left side where they are grouped toghether?
Planning to put this in the room where i watch movies in near pitch black, if there arent any LED's in the ports themselves i can just use some LED dim foil to cover them up.
Hi, @Dragan
The XMG1915-10E does not provide any built-in settings or options to disable the port indicator lights. Users cannot manually turn off these LED indicators through the device's configuration interface.
For more hardware layout of the XMG1915-10E, please navigate to Support & Learn > Download Library, and search for model: XMG1915-10E. You can click on the product’s icon to obtain a high-resolution picture of the hardware’s photo, or you can just click on the following link to take a close look at the product.
Link: XMG1915 Series | 2.5GbE Smart Managed Switch with SFP+ Ports | Zyxel Networks
Best Regard,
Lynn
Hi, @Dragan
Best Regard,
Lynn
Hi @Dragan,
If you want to turn off the Switch Link/ACT port LEDs, our XGS1250-12 model is equipped with LED ECO Mode. You can enable this mode to turn off all the Switch LINK/ACT port LEDs.
This post also provides an explanation of this feature for your reference.
Link:
What is the LED ECO Mode on the XGS1250-12 Switch Rev.B1? — Zyxel Community
Best Regard,
Lynn
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
