Zyxel XMG1915-10E LEDs?
Dragan
Dragan Posts: 1 image  Freshman Member
Does this Switch have the option to turn these off? if not, are there any LED's inside the ports or only on the left side where they are grouped toghether?
Planning to put this in the room where i watch movies in near pitch black, if there arent any LED's in the ports themselves i can just use some LED dim foil to cover them up.
  • Zyxel_Lynn
    Zyxel_Lynn Posts: 101 image  Zyxel Employee
    Hi, @Dragan
    The XMG1915-10E does not provide any built-in settings or options to disable the port indicator lights. Users cannot manually turn off these LED indicators through the device's configuration interface.
    For more hardware layout of the XMG1915-10E, please navigate to Support & Learn > Download Library, and search for model: XMG1915-10E. You can click on the product’s icon to obtain a high-resolution picture of the hardware’s photo, or you can just click on the following link to take a close look at the product.
    Link: XMG1915 Series | 2.5GbE Smart Managed Switch with SFP+ Ports | Zyxel Networks
    Best Regard,
    Lynn
  • Zyxel_Lynn
    Hi, @Dragan
    Best Regard,
    Lynn
  • Zyxel_Lynn
    edited July 2025
    Hi @Dragan,
    If you want to turn off the Switch Link/ACT port LEDs, our XGS1250-12 model is equipped with LED ECO Mode. You can enable this mode to turn off all the Switch LINK/ACT port LEDs.
    This post also provides an explanation of this feature for your reference.
    Link:
    What is the LED ECO Mode on the XGS1250-12 Switch Rev.B1? — Zyxel Community
    Best Regard,
    Lynn
