XS1930 default-gateway per each VLAN- Do I need L3 Access license?
Av3ng3r
Av3ng3r Posts: 14 image  Freshman Member
I am moving my configuration to multi vlan and I would like to add a default gateway per VLAN.
e.g. vlan 1 comes with the default gateway in the web based configuration.
I created vlan12 and I would like to assign its own default gateway but I do not see how to do it and in the show run I can see the default-gateway for VLA1 but not for VLAN2
Do I need the L3 access license LIC-ACSL3-ZZ0004F ?
vlan 1
  normal ""
  fixed 1-10
  forbidden ""
  untagged 1-10
  ip address 192.168.1.3 255.255.255.0
  ip address default-gateway 192.168.1.1
exit
vlan 2
  name VLAN2
  normal ""
  fixed 1-10
  forbidden ""
  untagged ""
  inactive
  ip address 192.168.2.3 .10 255.255.255.0
exit
    PeterUK Posts: 4,415 image  Guru Member
    edited July 2025
    I do not know of any other switch that allow many default gateway per VLAN and the XS1930 only has one default gateway for all VLANs. there is only the option to do static route for a given Destination to a given gateway.
    so your only option is to have many XS1930
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 409 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Hi @Av3ng3r,
    I am afraid that the L3 License can't fulfill your requirement. This is because the XS1930 does not support the function you're looking for.
    Can you share why you want to add the default gateway to per VLAN?
    I'd like to know the purpose and the complete scenario from you. Maybe we can have some suggestions for you.
    Thanks.
    Ivan
