ZyWALL110 Error Number: -16015 Error Message: 'Dial a dynamic tunnel has failed for Crypto map.'
Vyacheslav
server does not start vpn writes such an error Error Number: -16015 Error Message: 'Dial a dynamic tunnel has failed for Crypto map.' .did all the settings as written in the manual. Please Help me.
Best Answers
Dear @Vyacheslav
Thats because you are clicking on connect in the zywal webgui (that's mainly for device to the device connection)
L2TP in the zywall is commenly used as Server role. That means Zywall is server and u have to use a client (Windows pc, Iphone, Android) to dial in on the zywall..
So the Zywall will not iniate the connection like you tried with hitting connect.
here is an video how to configure a windows client:to succesfully use L2TP VPN with the zywall
https://youtu.be/BYxcjcOxybs
Show the available encryption options.
5 -
You need to turn on the encryption algorithms through the console.
5
Dear @Vyacheslav
Thanks !!!0
infoIKEISAKMP SA [L2TP_VPN_GW] is disconnectedinfoIKEReceived delete notificationinfoIKERecv:[HASH][DEL]infoIKESend:[HASH][NOTIFY:NO_PROPOSAL_CHOSEN]infoIKE[SA] : No proposal choseninfoIKE[ID] : Tunnel [L2TP_VPN] Phase 2 Local policy mismatchinfoIKERecv:[HASH][SA][NONCE][ID][ID]infoIKEРhase 1 IKE SA process done
Phase 1 and Phase 2 Proposal settings are the same.0 -
Please share your tunnel setting otherwise its difficult to see what wrong0
Add encryption in phase 1 and phase 2
In Zywall 110 (firmware 4.33) 3DES is missing. May be downgrade firmware to 4.25?0
5 -
5
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 319 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
