SSL VPN SecuExtender Retirement / Licenses for IPSec SecuExtender needed?
Hi @USG_User
Thanks for your update. Let us check if we can help on this wrong credential issue. I will keep you posted.
Zyxel Melen0 -
You can edit the local rasphone.pbk file (usually under %appdata%\roaming\……\connections\pbk) and change the value of "UseRasCredentials=0"
Simple idea: can you write a batch file on the windows client, first connecting the VPN tunnel and then performing whichever commands you do afterwards manually to connect to your shares?
- 441 Beta Program
- 210 Nebula Ideas
- 540 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
