my flex 200 doesn't recognize my usb storage
Hi @mnsandler
So, what is the result in Monitor > Network Status > USB Storage?
Also, did you activate the USB storage service in Configuration > System > USB Storage?
Zyxel Melen0 -
thanks for the reply. turns out i needed to format the usb stick using an MBR partition (not GPT)
would be nice if the zyxel would offer to format the usb storage to help avoid these issues
And it would be nice if it is possible to Auto safe an "known good" Config File on the Dongle (if someone with to so) in the case someone config something wrong.
Hi @mnsandler
Thanks for pointing this out. Let us update the the user's guide about this.
Zyxel Melen0 -
Update:
We will add the note in user's guide and online help.
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 501 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
