USG FLEX 500H SSL VPN How How to set up two user groups for split and full tunnel?
ITC_Sercop
ITC_Sercop Posts: 3 image  Freshman Member
Hy,
we need to create two user groups for SSL VPN (OpenVPN Client), one using split tunnel and one using full tunnel, but the GUI doesn't seem to allow it.
On the old USG firewall we could do it instead.
Do you have some tips?
Thank you.
    edited July 2025 Answer ✓
    Well there is a very easy way to do this but questionable as for security...
    So setup with Local Networks Only (Split Tunnel) and download the config then make a copy of the config to be used for Full Tunnel open that config in notepad edit under:
    verb 3
    with
    verb 3
    redirect-gateway
    you may need a routing rule
    incoming any
    Source Address of the VPN pool 192.168.51.0/24
    next hop WAN
    To tighten up security you can add block rule form users who should not use the FLEX H as the gateway should anyone work out they can just add redirect-gateway to there config.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,602 image  Zyxel Employee
    Hi @ITC_Sercop
    USG FLEX H(uOS) SSL VPN configuration is different from USG FLEX(ZLD). Could you share your scenario about why you need two different SSL VPN configuration for different users?
    Zyxel Melen
  • ITC_Sercop
    Yes, of course.
    Some VPN users need to connect to internet servers, in addition to our lan, that check the sender's IP address so it must be our IP Company Address.
    Other VPN users should use internet, while they are VPN connected, but they must use their internet connection to do so.
    Thanks.
    verb 3
    with
    verb 3
    redirect-gateway
    incoming any
    next hop WAN
  • Zyxel_Melen
  • ITC_Sercop
    thanks.
    Your advice works perfectly. You're right, we know it's questionable as for security and we have plans to use only the "Full Tunnel" option in the near future.
